DWF Viewer (Read Only)
Problem with AxCExpressViewerControl on 64 bit machine
1 REPLY 1
mahepriya
1667 Views, 1 Reply
I have a VB.Net windows application in which I have used AxCExpressViewerControl. Everything worked fine on 32 bit machine. But I face problem with 64 bit machine. When I use same application that works perfectly on 32 bit, it fails on 64 bit. I have added the AxCExpressViewerControl control at design time on my form. And when I try to run the application it is unable to the load the form also. I have faced this problem only with 64 bit and not on 32 bit. What could be the reason? Why it fails on 64 bit?
Thanks in advance.
1 REPLY 1
in reply to: mahepriya
You don't say what version of vb.net you are using; I had the same problem
with vb.net 2008.
The resolution to the problem was to set the project's Properties -
Compile - Advanced Compile Options... - Target CPU: x86
"mahepriya" wrote in message news:5946671@discussion.autodesk.com...
> Hi,
> Thanks in advance.
