DWF Viewer (Read Only)
Plot position in DWF's
3 REPLIES 3
272 Views, 3 Replies
Hi
In plotting to dwf's, it takes my nice left hand side margin (for binding)
and puts it on the right hand side.
(same problem with pdf's). Is there a way to adjust this?
regards
Nathan Ellery
NT Ellery
building design & consulting
wk/hm9472 0498 mob041 795 1575
3 REPLIES 3
HELP in AutoCAD explains how to set your plot origins.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
Thanks Dean
I found the offset on the plot menu.
That works but the final printed output won't print to scale or it leaks
onto a spare page.
I was experimenting with the page size print area in the pc3 file for the
specific sheet size & orientation.
Would be a lot easier if this was more straight forward.
It seems to me that it would be obvious that a drawing should be printed to
scale.
I guess I'll have to fiddle some more. The offset has helped so thanks for
the tip.
Nathan
"Dean Saadallah" wrote in message
> Dean Saadallah
It seems this should be an automatic process.
I would assume the plot sheet in ACAD (ADT2004) would be setup for hardcopy
output.
Printing to a dwf is supplimentary for checking etc so it should be a lot
simpler
Maybe taking it's settings from the hardcopy settings.
ie. I don't have to use the offset printing hardcopy.
Hopefully I can figure how to change this in the dwf.pc3 file.
venting - quietly
Nathan
news:F8B5F949AAF06099E6DB3BDC4C704A41@in.WebX.maYIadrTaRb...
> Dean Saadallah
