DWF Viewer (Read Only)
dockseal
286 Views, 2 Replies
opening file
I have installed Autodesk Express Viewer today and had a file sent to me with a .dwg extension. It does not appear to support this file extension. Is this the correct program to use? Or is there another program that should be used?
dockseal
2 REPLIES 2
cadsysmgr
in reply to: dockseal
The Express Viewer is ONLY for DWF file viewing. The
VoloView product line from AutoDesk is the one for DWG.
cadsysmgr
OOPS. I also should have added. For the NEW R2004 DWG
format you will need to purchase the VoloView 3 product
For DWG formats prior to R2004 you can get by with the
FREE VoloView Express 2.01 product.
There is also a Classic R14 style DWF file that VoloView
Express 2.01 can also view. This R14 style DWF generator
is loaded as a Print/Plot Driver. Lots of information to
research if you are inclined.
