We are looking at distributing our drawings in DWF format, which could save
a lot of time, not to mention trees. However, I've run into a problem with
it. Most all of our drawings have solid fills which we use to create shaded
portions on the drawings, like wall fills, for example. When I set the Merge
Control in the Plotter Configuration Editor for DWF6 ePlot to Lines Merge,
it doesn't seem to work. I know a workaround is to send the solid hatches to
the rear with Display Order, but I don't really want to do that.
