Hello All.
Although this viewer has the potential to solve a lot of legacy issues we have been dealing with, it is presenting a difficulty with regard to printing thematically mapped areas with the hatching. Solid colors come through perfectly, however, when an area has been configured to use a solid color along with a hatch the system changes the entire area to gray.
If you are thinking that we should just use solid colors, I would just like to make you aware of the fact that we are not in a position to change the graphical configuration for the data items since they are being set through an application (using xml) on hundreds of different data types by several users.
We are using a Mapguide 6.3 Server and Author to generate our mwfs. Does this have anything to do with it?
