At this point, you should go for the temp file, we'd have to do some
additional API work to get it to do what you want. On the bright side, if I
recall propertly, there's a CreateFile setting that tells the OS to keep the
file in memory if possible. For downstream consumers of said file, it
appears as though the file were on your disk. Good luck.
"Joel Lucsy" wrote in message
news:Xns934B725C56C26jjlucsy@64.124.46.110...
> How does one get Express Viewer to load a DWF from memory? I thought that
> you might have to construct an IStream to pass to _ReadSourceStream, but
> it GPF's. If I need to I can write out the DWF to a file, but I'm trying
> to avoid that scenario. Thanks.
> P.S. - This is a C++ app.
> Joel Lucsy (jjl@cadfx.com) http://www.cadfx.com
