DWF Viewer (Read Only)
Message 1 of 20
wjackson
889 Views, 19 Replies
Install Fix??
DLL problems:
Come on guys, you "might" have a fix. Many of us really need this issue resolved, especially when your telling everyone to ditch VoloView for AEV.
19 REPLIES 19
Message 2 of 20
in reply to: wjackson
Can you be more specific?  The NNTP newsgroup
side doesn't seem to keep the threads forever.  What is the issue you're
having?
DLL
problems:
for AEV.
Message 3 of 20
wjackson
0001\F7\AdPageView.dll There was a problem regiestering this file. > The installation will be cancelled.
Here is a variation of the theme:
The setup crashes/simply exits during registration of COM components.
Message 4 of 20
So run depends.exe and tell us what it says is
missing. There will be a little yellow warning sign next to the missing DLL. You
can get depends from
href="http://www.dependencywalker.com">http://www.dependencywalker.com
cancelled.
components.
Message 5 of 20
wjackson
Warning: At least one delay-load dependency module was not found.
Warning: At least one module has an unresolved import due to a missing export function in a delay-load dependent module.
APPHELP.DLL
Message 6 of 20
wjackson
Why am I supplying all this info again? Its in 4 other threads with people (edited) about it.
Message 7 of 20
What is your OS / SP level and IE
version?
Warning:
Warning: At least
APPHELP.DLL
Message 8 of 20
Gee. Your words make us wish to help you
so.
"wescfa" wrote in message
news:f15ee74.4@WebX.maYIadrTaRb...Why
(edited) about it.
Message 9 of 20
wjackson
(edited by moderator - review guidlines please)
Autodesk,
OS Name Microsoft Windows 2000 Professional
Version 5.0.2195 Service Pack 3 Build 2195
IE 6.0.2800.1106C0
Message 10 of 20
cadsysmgr
While Scott counts to 10 I will reply. SCOTT is not
playing. He knows his stuff and is NOT GOING TO search
a boat load of threads to PATCH your problem together.
IF he asks for information give it too him. That is IF
you really want the help.
Message 11 of 20
wjackson
The real problem is, I shouldn't have had to start another thread on this. We should have had one thread on this issue since it seems to be a fairly large problem. Scott, I apologize for any rude comments directed towards you. I was just bent because of the lack of help for those guys who have been having this issue.
Message 12 of 20
The problem is one of reproducibility.  After
several months, we have not been able to reproduce it in house.  If any AEV
users have found the magic juju which corrects this problem, or any other clues
to help solve it, we could proceed further.
The
issue.
Message 13 of 20
I cannot view the posters original message.
All I get is: "(edited by moderator -
" if the poster could repost the symptoms in
such a fashion that the moderator doesn't get offended, maybe the
group could help out.
"Jeffrey Klug (Autodesk)" <jeffrey dot klug at autodesk dot com>
wrote in message
href="news:809134C1933D69DA2D8428C5421365AA@in.WebX.maYIadrTaRb">news:809134C1933D69DA2D8428C5421...
After several months, we have not been able to reproduce it in house.  If
any AEV users have found the magic juju which corrects this problem, or any
other clues to help solve it, we could proceed further.
The
having this issue.
Message 14 of 20
Depends returns:
APPHELP.DLL
The other information:
Pack 3 Build 2195
IE 6.0.2800.1106C0
wrote in message
href="news:809134C1933D69DA2D8428C5421365AA@in.WebX.maYIadrTaRb">news:809134C1933D69DA2D8428C54...
If any AEV users have found the magic juju which corrects this problem, or
any other clues to help solve it, we could proceed further.
The
Message 15 of 20
I am running:
Windows XP Professional
Version 2002 Service Pack 1 (All items up to date
from Windows Update)
IE 6.0.2800.1106.xpsp2.021108-1929
What's weird is that I get:
when I run depends. Despite this AEV is
working for me.
When I look for the cause of this error
message, I see MPR.dll, Multiple Provider Router DLL, a DLL from Microsoft, that
is the culprit. My version of this DLL is 5.1.2600.0. Many of my other system
DLLs are 5.1.2600.1106. Based on that 1106 number and my version info for IE 6,
these probably came with IE 6.0. Why IE 6.0 does not have a new MPR.DLL is
beyond me. Does anyone know what product could be installed to upgrade MPR.DLL
to a newer version. That is the trick here. There is nothing wrong with AEV. We
just need a way to upgrade the underlying system, so that all of the necessary
components are present.
Hey
Sheppard, go play in another thread.
Autodesk,
Version
IE
6.0.2800.1106C0
Message 16 of 20
FWIW, I have the same MPR on my machine, and the
same delay-load module warning.  However, I don't get the problem with
AppHelp.dll that wescfa reported.  We're scratching our heads
here.
I am running:
is working for me.
error message, I see MPR.dll, Multiple Provider Router DLL, a DLL from
Microsoft, that is the culprit. My version of this DLL is 5.1.2600.0. Many of
my other system DLLs are 5.1.2600.1106. Based on that 1106 number and my
version info for IE 6, these probably came with IE 6.0. Why IE 6.0 does not
have a new MPR.DLL is beyond me. Does anyone know what product could be
installed to upgrade MPR.DLL to a newer version. That is the trick here. There
is nothing wrong with AEV. We just need a way to upgrade the underlying
system, so that all of the necessary components are
present.
Hey
Autodesk,
Version
IE
6.0.2800.1106C0
Message 17 of 20
I have the same problem with MPR.DLL on with the
*exact* same OS and IE specs as JK.  I think that wescfa should walk his
APPHELP.DLL to see if there is another problem there.  It sounds like he
might have a displaced, incompatible or corrupt system file.  Maybe
there's one that just needs to be re-registered.  If any of these things
are the case, the issue might eventually manifest itself in other
areas, not just AEV.
wrote in message
href="news:53DFAD4CB200F21B035F7BF13BAA7C4C@in.WebX.maYIadrTaRb">news:53DFAD4CB200F21B035F7BF13BAA7...
here.
I am running:
date from Windows Update)
AEV is working for me.
of my other system DLLs are 5.1.2600.1106. Based on that 1106 number and my
There is nothing wrong with AEV. We just need a way to upgrade the
underlying system, so that all of the necessary components are
present.
Hey
Autodesk,
Version
IE
6.0.2800.1106C0
Message 18 of 20
The only thing edited out was profanity. All content remains in
the message thread.
Anne Brown
Manager, Moderator
Autodesk Product Support Discussion Groups
Discussion Q&A: http://www.autodesk.com/discussion
Peter Lone wrote:
> I cannot view the posters original message. All I get
> is: "(edited by moderator - review guidlines please) " if the
> poster could repost the symptoms in such a fashion that the
> moderator doesn't get offended, maybe the group could help out.
Message 19 of 20
wjackson
Peter, what do you mean by "walk the dll"? I'll do whatever I can to help AD get this problem resolved. Out of 100 or so workstations I have a total of 7 systems with this problem. Out of those 7 I have 4 NT, 2 2K and 1 XP. Scott, if AEV is dependent of this particular version of MPR.DLL shouldn't it be included with the install or at least noted?
Message 20 of 20
The MPR.DLL thing is a red herring.  It's more
likely APPHELP.DLL, but that too is likely not the root issue.
Peter,
