DWF Viewer (Read Only)
IE8 Crashes when rotating a 3d model
1 REPLY 1
Paulio
1517 Views, 1 Reply
We have a web application which shows a 3d model using the Desing Review 2011 activex plugin. This all works fine with the exception of a single machine upon which IE8 crashes with an 'Internet Explorer has encountered an error' message when attempting to rotate the model; zooming and panning are fine.
The event log shows the following:
Faulting application iexplore.exe, version 8.0.6001.18702, stamp 49b3ad2e, faulting module dx9_1701.hdi, version 1701.1.0.0, stamp 4b4ae554, debug? 0, fault address 0x0001f8df.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
The machine has windows Xp pro Sp3.
It's not a particularly complex model and the dwf is only about 1.3meg.
We've tried it on a seemingly identically set up machine and even a much lower spec one and it works fine.
Thanks in advance for any light you may be able to shed on this.
1 REPLY 1
herbert.he
in reply to: Paulio
Thank you for reporting this issue.
We have logged a defect for this issue. We will consider fixing it in future releases.
For now, you can try the following steps to resolve this issue:
1. Launch Autodesk Design Review.
2. Select 'Options...' from right click menu.
3. Open 'Model' tab.
4. Change the Driver to 'Software (OpenGL)'.
Please reply back if this solution works.
-Herbert
ADR/DWF Customer Support
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
