DWF Viewer (Read Only)
IE DWG Viewer Error.
1 REPLY 1
cvstech01
1354 Views, 1 Reply
I cant seem to figure out why I can not view .ipt files with IE. I have the newest version of autodesk design review. I get the error accross the top of IE that says "This visualization file is not a system controlled visualization file. Use Update View" ....then there are a number of IE script errors that pop up and thedrawing does not display.
The Ipt files are being accessed through a product stream vault.
1 REPLY 1
in reply to: cvstech01
Autodesk DWG TrueView (http://www.autodesk.com/dwgtrueview) allows you to
view DWG files.
Autdoesk Design Review (http://www.autodesk.com/designreview) allows you to
view DFW files.
Inventor View (http://www.autodesk.com/inventorview) allows you to view
Inventor files like IPT. Which do you have installed.
wrote in message news:6332209@discussion.autodesk.com...
