DWF Viewer (Read Only)
area98
12596 Views, 2 Replies
hztxt.shx font
Hi I need help.
I received some ".dwg" drawing from AutoCAD user in China. When I view it using the DWG viewer, I receive an error "hztxt.shx" font not found.
According to Autodesk technical support, this font belongs to microsoft.
According to Microsoft technical support, this font belong to AutoCAD and was installed in the user workstation during installation of AutoCAD.
Since I am using only the DGW viewer, this font is not available in the viewer, hence I can't see this font and it is displayed as "??????".
Can anyone help to resolve this so that I can view the full drawing?
Many thanks
2 REPLIES 2
in reply to: area98
You contact your sender, ask for the file.
Your sender should include all items you need to view their
files: if they use AutoCAD, introduce them to the command
ETRANSMIT with it's many options, including font inclusion.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
in reply to: area98
I am under the impression that SHX fonts are part of AutoCAD. It is likely
that this font ships and gets installed with the Simplified Chinese version
of AutoCAD. My guess is that this font does not ship and get installed with
the English version of DWF Composer (DWG Viewer in this case). As SHX font,
I believe you can ask the AutoCAD user in China to send it to you.
Alternatively, this user can use the eTransit feature to package up all of
the files that you might need to properly view the DWG.
wrote in message news:4893502@discussion.autodesk.com...
Hi I need help.
Many thanks
