DWF Viewer (Read Only)
How to remove "Getting Started" and "Check for Updates" p
2 REPLIES 2
270 Views, 2 Replies
I'm testing out Autodesk Express Viewer 4 in a Windows 2000, Citrix XP environment. I need to disable the "Getting Started" and "Check for Updates" pages from popping up. Anyone know what registry keys need to be changed and what the value must be?
Thanks!
2 REPLIES 2
Please be aware that the environment used by you
is untested and hence unsupported.
VJoseph
I'm
Thanks!
The "Getting Started" can be turn off after the 1st run by selecting the
check box "Show this page when Autodesk Express Viewer is Started".
For the Check for Updates, in the registry under
HKEY_CURRENT_USER\Software\Autodesk\Express
Viewer\4.0\Preferences\AutoUpdate there are a couple of keys you can change
You can change CheckInterval to some very high number, default is 90, so
after 90 days AEV will check again. After a 1st install you can alter the
value for InitialCheck to 1, this will suppress the 1st run check.
While you are here, I can point out to you the Uer Interface section, here
you can add "Suppress Startup Page", set as a REG_DWORD and set the value to
0. This will suppress the startup page.
"bclaus" wrote in message
news:f1a201d.-1@WebX.maYIadrTaRb...
> Thanks!
