Show only
Search instead for
how to detect if autodesk express viewer (or voloview) is installed via explorer
Here is what I use. Watch out for some line wraping. Hopefully you can sort
it out. I have this in the html OnLoad event handler.
On Error Resume Next
Err.Clear
Set tempObj = CreateObject("WHIP.WhipCtrl.1") 'AutoDesk Whip! Viewer
If Err.Number = 0 Then
document.write ""
End If
if Err.Number <> 0 then
Err.Clear
Set tempObj = CreateObject("AdView.AdViewer") 'AutoDesk Express Viewer
document.Write ""
End If
End If
Err.Clear
Set tempObj = CreateObject("AvViewX.AvViewX") 'AutoDesk Volo View Express
document.Write ""
End If
End If
if Err.Number <> 0 then msgbox "You do not have a compatible drawing viewer
installed. Either Whip! or VoloView are required to view drawings. Please
notify your Systems Specialist.",,"Missing Drawing Viewer"
