DWF Viewer (Read Only)
Get text position and transform cordinate DWFTOOLKIT 7.6
1 REPLY 1
sebastien_lourdel
2689 Views, 1 Reply
i use dwftoolkit 7.6 to extracting all text on dwf and i get the position X and Y but x = 2147482397
I use the sample namely DwfStrings.
How transforming cordinate dwf to cordinate DWG?
best regards,
1 REPLY 1
Thank you for your question. Firstly, the text position needs to apply the transform matrix (DWFGraphicResource::transform()). Secondly, if the text is in a viewport, then text position should apply the viewport transform (Please refer to the DWF Toolkit docs). Thirdly, the position is in logical unit, position/100,000 can get the coordinates in inch unit. At last, please let me know where is the DwfStrings you get from? Silvia ADR/DWF Customer Support
Silvia Cao
SW Engineer
PSEB-GE- ACRD PSEB
Autodesk, Inc.
