People act like PDF is a bad thing. If it meets your needs, you certainly
should use it until DWF meets your needs. If your process involves using a
DWG with AutoCAD, generating a DWF and sending it to someone who has DWF
Composer, who marks up the DWF, sends it back, and then the original DWG is
updated based on the DWF, then you do have a legitimate roadblock. But since
this is a print to fit page issue, my guess is that you are using a
paper-based process (hopefully printed using Oce equipment). The 999% zoom
limitation has been acknowledged as a bug. I am guessing it will get the
attention it deserves in the next release. My fear is that update will be
too late for your needs. With 32 bit integers, the data points can only be
scaled so far. My guess is that 999% was picked for a reason.
"Rick Mattingly" wrote in message
news:14118360.1102092076004.JavaMail.jive@jiveforum1.autodesk.com...
> Whatever this is Ben, it is a major issue. Looking back through the
> messages
> here I see that a number of people have complained about this shortcoming
> with the newest upgrade of the Viewer, including myself. I even see people
> asking for access to older versions of the Viewer which did not include
> this
> great new feature (flaw!).
> I attempted to resolve the problem by printing to DWF size of 24x36 rather
> than 8-1/2x11. Still comes up with the 999% zoom error and simply does not
> work. If we can't print 'Fit to Page' what we view the latest version of
> the
> DWF Viewer application is seriously flawed! Unless something is done to
> correct this soon we will be forced to drop support for DWF in our
> operations here.
