DWF Viewer (Read Only)
Express Viewer ghost image on Windows 95/98
7 REPLIES 7
Message 1 of 8
411 Views, 7 Replies
Express Viewer (v3,1,0,78) is acting weird on Windows 95/98 when used inside frames.
I was able to reproduce it with a simple webpage at
        www.dijkoraadonline.nl/testexpress
To the left is a frame with just some text, to the right is a htm page with a viewer through
the object tag.
Initially the page shows fine but as soon as I touch the scrollbar of the left frame a copy
of the image in the viewer is displayed on the top left of my desktop. See also
        www.dijkoraadonline.nl/testexpress/everror.png
This happens on a (very clean, freshly installed) Windows 95 with IE 5.5 and also on a
Windows 98 SE with IE 6.0. It works fine on any Windows NT machine I tried.
When I close IE on the 95 machine I get:
IEXPLORE caused an invalid page fault in
module ADPAGEVIEW.DLL at 0137:01d985ed.
Registers:
EAX=016b0078 CS=0137 EIP=01d985ed EFLGS=00210202
EBX=01cd0000 SS=013f ESP=0058ea98 EBP=0058eab4
ECX=016b033c DS=013f ESI=00000000 FS=3327
EDX=8161df44 ES=013f EDI=00000000 GS=0000
Bytes at CS:EIP:
8b 09 85 c9 74 07 ff d1 a1 98 91 e5 01 83 2d 94
Stack dump:
01d98693 01cd0000 00000000 00000000 01cd0000 81624338 816148ac 0058ec80 bff7b9b5 01cd0000
00000001 00000000 01cd0000 81624338 816148ac 00000000
Anyone any solution??
7 REPLIES 7
Message 2 of 8
System Requirements
a.. Intel® Pentium®-based PC, 133MHz processor or faster
b.. Microsoft Windows XP, Windows 2000, Windows 98, or Windows NT® 4.0
(SP4 or higher)
c.. 32MB RAM (minimum)
d.. 800x600 video display or higher
e.. Microsoft Internet Explorer 5.01 or higher (required only for ActiveX
viewer)
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=2404497
Otherwise your link works fine in non-Win95, tested it in Win98SE, works
fine, so does NT4/2000/XP/ME.
Dean Saadallah
http://www.pendean.com
LT Express Utilities
http://www.pendean.com/ltexpress
Expanded Links Pages
http://www.pendean.com/lt/links.htm
Message 3 of 8
Oops, you are correct, it is not supposed to work on 95
Fact remains that it does not work on my 98SE (with the same error as on 95) either.
Too bad it does work on you 98SE 🙂
Jos
In article <4D731AE448474CC73A2033F3FE5D820C@in.WebX.maYIadrTaRb>, info@NOSPAMpendean.com
says...
> System Requirements
> (SP4 or higher)
> viewer)
> Dean Saadallah
Jos Groot Lipman
Visit www.furix.com for BetterWMF and CompareDWG
Furix BV
Message 4 of 8
joneschester
I get exactly the same problem!
Autodesk?
Message 5 of 8
I also get the same problem on Win98. I tried it without using Frames and still get the problem. See topic titled Windows 98 Viewer Problem on 3/18/03 for my description of this problem.
Message 6 of 8
Do these "ghost" images persist, or is it just a
momentary flash and then once things "settle" all is good?
If it doesn't persist, we know what the problem is
and it will take some working with Microsoft to get some fixes in the ATL
libraries we use in our architecture.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
Message 7 of 8
The Ghost image does persist (otherwhise I would
not have been able to make the screenshot at
href="http://www.dijkoraadonline.nl/testexpress/everror.png">
face="Times New Roman"
size=3>www.di...
There is also a momentary flash of the Viewer on
the top left of my Internet Explorer on Windows NT but as this is only 1 second
at initial loading of the Viewer I can live with that.
 Jos
"Jeffrey Klug (Autodesk)" <jeffrey dot klug at autodesk dot com>
wrote in message
href="news:41A266B2285BB931637B3AB9A541547D@in.WebX.maYIadrTaRb">news:41A266B2285BB931637B3AB9A54...
is and it will take some working with Microsoft to get some fixes in the ATL
I
Message 8 of 8
The images definitely persist. When you scroll into the AEV area the image in the viewer actually "takes over" the left half of the screen. If you scroll back out of the AEV area, minimize your browser, then resize it the screen will clear up - until you scroll back into the AEV area.
