I increased the resolution but it still plots out the solid lines in the
solid hatch areas. I zoomed up in the dwf file and they don't show up on my
screen so it must be my output devise. I printed the same dwf to our hp
printer and it came out fine. What I don't understand is that the original
plotter, the one we print all our dwg files to, is the one giving me the
problems. (it is an Oce9600). It uses the hpgl/2 language just like the HP.
Thanks for the help and if you have any other ideas, I am listening.
"Matt Kolberg" wrote in message
news:660697FDA45BA9579199B62FCB43581A@in.WebX.maYIadrTaRb...
> This may have something to do with the resolution of your DWF file. Are
you
> zoomed in quite close when you see these triangles? You may need to
> increase the resolution if they show up in the final print.
> "Jim Raesly" wrote in message
> news:F0F4915B8A9120F17D42B853E43EA521@in.WebX.maYIadrTaRb...
> > I just tried out the new AEV with a single DWF file I created.
Everything
> > plotted fine except that the solid hatch that is part of my ADT walls
> shows
> > the "edges" of the hatch. It looks like a bunch of solid filled
triangles
> > within the thickness of my walls. Is there any way of hiding the edges
of
> > these tiangular fills? Thanks.
> > Jim
