I'm doing coding on Design review in c# but I couldn't load the Autodesk DWF Viewer Control anymore into my Visual studio 2010 since I installed Visual studio 2010 from 2008.
Do you know what the problem is? All the dll file from autodesk only can supports in Visual studio 2008?
or is it problem my computer is x64?
Please let me know.
I could do this stuff when I was using Visual studio 2008 in x32 computer.
Jinsol
Thank you for your question.
It should be a 64 bit problem.
The issue you reported is similar to the one reported in http://forums.autodesk.com/t5/Autodesk-DWF-Viewer/Problem-with-AxCExpressViewerControl-on-64-bit-mac.... Please try the solution posted in that thread.
Hope this helps.
Please let know if you have any further question.
Thank you for your reply.
I did like the explanation but the following problem pops-up
'Failed to import the ActiveX control. Please ensure it is properly registered.'
I've been trying to solve out this problem but it fails.
I guess it is from the confusion problem between .NET Framework 4.0 and Visual studio 2010.
Do you know any way to solve out this problem? I feel frustrated. Please help me.
Thank you for your feedback.
I cannot reproduce your issue with .NET Framework 4.0 and Visual studio 2010.
Please insure Design Review works well on your machine.
Please let me know if you have any further question.
