DWF Viewer (Read Only)
Error When Opening DWF File
1 REPLY 1
hamilton318
1478 Views, 1 Reply
Using
Autodesk Design Review version 11.0.0.86
Windows XP Pro SP3
Intel Core 2 Duo 2.53 GHz
3 Gb Ram
When trying to open a .dwf file, I get the error : Your current version of Design Review does not support files of this type.
Any ideas?
1 REPLY 1
pendean
in reply to: hamilton318
Your DWF is either corrupt, or you need to rename it from FILENAME.DWF to FILENAME.dwf (not caps for extension). Helps if you have Windows Explorer set to show file extensions, otherwise you will not be able to change it where it matters.
