DWF Viewer (Read Only)
Error message opening DWFx files
4 REPLIES 4
3639 Views, 4 Replies
I have made website and use control:
object id="ADViewer" classid="clsid:A662DA7E-CCB7-4743-B71A-D817F6D575DF"
    width="800" height="640" VIEWASTEXT
    param id="dwfvalue" name="Src" runat="server" value=""
object
It's working with DWF files very well. Thanks
However when I tried to open *.DWFX file I have got message then this file's type doesn't support.
The wheels product given me same error.
Could you give me any help?
Mikhail
4 REPLIES 4
herbert.he
Thank you for your question.
If *.DWFx files also cannot being opened by Autodesk Design Review (ADR) directly. Please uninstall and reinstall ADR from here.
Please let me know if I can be of any further assistance.
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
Autodesk, Inc.
Hello herbert.he,
Thanks for your message.
Today I have found one more reason. I have created two similar html-pages and put their on two different websites. One page is working very well, second one is not working. I don't know kind of first server, but know second one - IIS7.
Do you know what I have to change on IIS7?
This example is working
This example has the error message
Mikhail
herbert.he
Thank you for your feedback.
Both of your examples are working on my side, see the attached snapshots.
And I noticed that there are some script code differences between your two examples. Please edit the example which has the error message accordingly, and then try again.
Any further questions please let me know.
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
Autodesk, Inc.
Thank for the answer. You right - now it is working. It was some issue on the server.
Mikhail
