DWF Viewer (Read Only)
ERROR (0x642:internal error)
6 REPLIES 6
ingfrias
2004 Views, 6 Replies
Cuando quiero instalar el DWF Viewer, me sale ese error, alguien me puede orientar como hacer para solucionarlo.
Daniel Frias
6 REPLIES 6
dieterfriedli
in reply to: ingfrias
I have the same error... While installing Autodesk Design Review 2010, the error "DWF TrueView (0x643: Internal Error)" appears... What could we do?
Grab a freebie called REVO UNINSTALLER, use it's most aggressive setting to
remove your old version of ADR and any signs of the new one. Also get and
use a Windows Registry Cleaner (if you have other Autodesk products, be
prepared to reinstall them).
Restart Windows, try a new install.
"0x643: Internal Error" is a Windows system problem related to the Registry
from what I understand.
Dean Saadallah
http://LTisACAD.blogspot.com
codywohlers
I can confirm that Design Review 2010 doesn't install with Vista Business x64 with Inventor Suite 2009 installed. Downloaded the installer from http://www.autodesk.com/designreview-download and at first VB 2008 C++ runtime failed with 0x642 internal error. A manual download and install of VB 2008 C++ runtime resolved that error but now install fails with Design Review 2010 0x642 internal error. Removed True View 2009 and Design Review 2009 from Windows Add/Remove Programs and the error persists. Had to give up and reinstall Design Review 2009 from http://download.autodesk.com/esd/designreview/SetupDesignReview2009.exe just to get back to work. Very disappointing.
guok
Thank you for your question.
Please uninstall ADR 2009, and make sure the following two Autodesk Design Review folders are empty,
[%ProgramFile%]\Autodesk\Autodesk Design Review
[%CommonProgramFiles%]\Autodesk Shared\DWF Common
If there are files remaining, please delete the contents of those two folders.
Then install ADR 2010.
For more details, please refer to http://discussion.autodesk.com/forums/thread.jspa?threadID=726759&tstart=0
http://discussion.autodesk.com/forums/thread.jspa?threadID=725771&tstart=0
Please let me know if you have any further questions.
- Kenny
Kenny Guo
SW Engineer
Autodesk, Inc.
dharmendrasingh
hello
codywohlers
Thanks guok for your help, but it turns out I had a different problem. I uninstalled ADR 2009 and the mentioned folders were not present. I again tried to install ADR 2010 using the online installer (from http://usa.autodesk.com/adsk/servlet/pc/index?id=12423405&siteID=123112). That again failed with 0x642 for the visual basic runtimes (which i manually installed). I then downloaded the offline installer (from http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=10336080) and it told me the visual basic runtimes were missing (but I manually installed..?). After re-reading the help (from http://download.autodesk.com/esd/designreview/2010/ADR_Install_Guide.htm) it mentioned downloading the vb runtimes and provided links to microsoft's website for the x86 versions. I assumed that i needed the x64 versions for my 64-bit computer but after installing the x86 versions, the offline installer worked fine.
So I guess using x86 vb-runtimes and using the offline installer works. (Haven't tried the online installer with x86 vb-runtimes pre-installed, but I'm guessing maybe the online installer is trying to install the x64 versions? and results in the 0x642 error? (just a guess)).
