DWF Viewer (Read Only)
Edit DWF file in C#
3 REPLIES 3
chaitanya_tyagi
1077 Views, 3 Replies
Edit DWF file in C#
Hi ,
I want to edit a "DWF" file in C#.I would like to know about the Autodesk SDK which support C#. If its possible then From where i can download the Autodesk SDK for C#?
Or it's possible only in C++?
Chaitanya
Tags (1)
3 REPLIES 3
in reply to: chaitanya_tyagi
The DWF Toolkit is currently available in C++. You can use .NET with managed
C++.
wrote in message news:5578213@discussion.autodesk.com...
Hi ,
Chaitanya
Thanks for your quick reply. I am a C#.Net programmer and don’t know about the C++.
I have installed the DWF viewer on my system and after that I got some COM component and by the help of them i am able to view the DWF file either in C# or VB.net. But I am not able to edit the DWF file. So I want to ask again about the editing of the DWF file. Is it possible if I installed the DWF writer on the machine and able to edit the DWF file in C#?
Does it make sense?
Or there is only way to edit the DWF file by using of C++?
Chaitanya
The only way to edit a DWF file is with C++. The APIs to Autodesk Design
Review or the DWF Viewer do not allow the file to be edited.
wrote in message news:5579701@discussion.autodesk.com...
Thanks for your quick reply. I am a C#.Net programmer and don't know about
the C++.
Does it make sense?
Chaitanya
