we have the same problem in our company.
After starting DWF Viewer 7 (Version 7.0.0.928), it hangs and nothing happens for 5-10 Minutes. then it comes up.
I tracked down the problem:
- Nothing to do with user rights.
- Nothing to do with IE settings ore something else in the environment
- Workstations are only affected, if there was DWF Viewer 6.5 installed (and used!!!) before.
Seems that the uninstall of Version 6.5 leaves something on the machines that kills Version 7.
A similiar Problem is with DWG Trueview 2007 and Inventor Viewer 11 (will post there).
At the moment 500 users can not work in our company.
Please Autodesk, you killed 500 machines in our company - so get a solution!!!
Normally you are just killing "only" design machines with new version.
Will there be a chance that you release once a product that do not crash. Or that you test it - only once? Just try to start Inventor or MDT (9, 10 or 11) with default user rights (anything else is no testing!!!). Ever had that idea?
Sorry, I am really sucked up.
Waiting for your reply
Clemens
