The "There was a problem displaying the model." means one of two things.
1. The file is bad. There is a bug in the software used to create the file
or something happened during the creation of the file. If this is the case,
nothing can be done with the file except get a new copy that is published
correctly.
2. There is a defect in the viewer that the file is uncovering. If this is
the case, nothing can be done with that exact file until a viewer update
comes out. A work around is to change something about the source data,
generate a new file, and see if the new file uncovers the same problem.
My point is that a message like this is NOT normally associated with your
install. So don't spend any time uninstalling and re-installing.
wrote in message news:5328687@discussion.autodesk.com...
I have DWF V7 installed with the latest updates from IE6.
I have some sample DWF files that load if the file is very small (7k) but
when I try opening larger files (500k to 1.5mb) the details load (in the
menu bars on the LHS) but the image only flashes quickly before displaying
an error;
"there was a problem displaying the model".
I have un / re installed a number of times to no avail - is anyone else
having this problem?
