DWF Viewer (Read Only)
DWF file not rendering in the DWF sheet properly
5 REPLIES 5
1662 Views, 5 Replies
Using C# and the AxExpressViewerDll control. I am trying to set the sourcepath to a local DWF file. I am using the OnEndLoadItemEventHandler to do this:
private void DwfViewer_OnEndLoadItem(object sender, AxExpressViewerDll.IAdViewerEvents_OnEndLoadItemEvent e)
string strItem = e.bstrItemName;
if (strItem == "DOCUMENT")
DwfViewer.SourcePath = "C:\\Data\Test.dwf";
The file does load but it is shown offset in the viewer instead of filling up the Canvas. This only happens using the OnEndLoadItemEventHandler as shown above. If I set the sourcepath after the control is already completed it renders properly. I have attached an image of the offset DWF in the control.
5 REPLIES 5
herbert.he
Thank you for your question.
Please use the API ECompositeViewer.IAdECompositeViewer.SourcePath to set the sourcepath directly instead of OnEndLoadItemEventHandler.
Please refer to the ADR API documentation for more information.
Any further questions please let me know.
-Herbert
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
Autodesk, Inc.
The problem is you cannot set the sourcepath until the AxCExpressViewerControl has completely loaded. We are launching a popup window which opens a Windows Presentation Foundation (WPF) window. If I try to set the source path directly it crashes because the AxCExpressViewerControl is in an invalid state. If you look at the ViewerEvents.OnEndLoadItem Event in the API docs you will see how it describes being able to set the source path within this event. Again it does work its just the DWF is placed offset in the canvas as shown in the previous post attachment.
Thanks so much for the help and let me know if you know of anything else.
herbert.he
Thank you for your feedback.
Could you provide a test application with test file that caused this issue so that we can reproduce and investigate it?
-Herbert
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
Autodesk, Inc.
I am having the same issue's. Map 2008 has no issue's, but when I upgraded to 2010 it seems to do this to some of my maps as well. It zooms to a specific spot instead of the entire drawing. So when you open a .dwf that was published it is zoomed way in or off tot he side instead of actually coming in as designed in the setup process.
Chad Kersten
Minot, ND Edited by: chadlk@srttel.com on Mar 23, 2010 10:27 AM
herbert.he
Your question seems a DWF publisher issue of Map 3D. I suggest that you can post your question in AutoCAD Map 3D Forum.
Thank you for your supporting Autodesk.
-Herbert
Herbert He
SW Engineer
PSEB-GE- ACRD PSEB
Autodesk, Inc.
