I'm having a frustrating run of things. Here's the deal:
I first started using Revit Building 8 and created DWF files by printing to the DWF Writer that was included with that Revit release. It was installed separately and things seemed to work fine.
Then I upgraded to Revit Building 8.1. The DWF Writer no longer came with it and the export function didn't work for 2D drawings. So, I installed the writer from the 8.0 CD. This seemed to work fine.
Now I'm using Revit Building 9 and the export to 2D DWF feature is fully functional. The DWF files that I create using it look just like the ought to. When I print the DWF to a physical printer here in the office (no matter which one and they're all different) everything prints correctly.
So why am I frustrated? Because if I send the file to my reprographer (is that a word?), some of the text, but not all, gets messed up. Also, section, elevation and callout tag heads and tails are dropped out of the print. Finally, the section lines appear to be lighter than usual.
As a work around, the reprographer asked me to print to PDF instead. I thought, "I have the latest and greatest Adobe Acrobat Pro and Distiller, so that shouldn't be a big deal". Well, the text is fine but the tag heads and tails still drop out - and that's in the PDF so I didn't bother sending it to the print house.
Now here's the thing. I installed the old DWF Writer from the v. 8 CD. If I print the Revit file to that "printer" instead of using the native export function, all of these problems are again resolved. This suggests to me that the problem is with the DWF file as a result of the new export function. I know there are threads related to DWF and the Oce Reprographics system, but they don't address the similar problems when printing to PDF. They don't specifically address these other problems either.
Can anyone shed any light?
