Hmm. After you uninstall, try going into the install directory, which is
probably C:\Program Files\Autodesk\Autodesk DWF Viewer, and deleting it and
all its subdirectories. There may be script files in there that do not get
removed by the uninstaller and are causing problems when you reinstall.
"Dasboot" wrote in message
news:21219840.1093877714470.JavaMail.jive@jiveforum2.autodesk.com...
> I have uninstalled - rebooted - reinstalled and rebooted and still I get
the script errors in the htm files supplied in the installation.
> The script errors are constant.
> index.htm - line 54 char 13
> controlpane.htm line 88 char 9
> controlpane.htm line 101 char 13
> Object does not support this property or method.
> Then the drawing opens, however if I click on the "Reload" button the
entire program crashes with object not found.
> Am I supposed to edit the htm files supplied by AutoDesk??
