DWF Viewer
DWF Viewer
Distinguished Contributor
ssx_Autodesk
Message 1 of 3 (3,929 Views)
Difference between AutoCAD Application and AutoCAD DWG Launcher
3929 Views, 2 Replies
10-18-2010 06:25 AM
why does true view take over dwg associations seemingly by simply opening the application??
now i have to go figure out how to get AutoCAD back as the default dwg app AND have it opening files the way i want.
get it together autodesk.
______________________________
~ "if this were /. this would be funny"
pendean
Message 2 of 3 (3,928 Views)
Re: Difference between AutoCAD Application and AutoCAD DWG Launcher
10-18-2010 08:17 AM in reply to: ssx_Autodesk
Last 'dwg' app started takes over: if you had multiple DOC or XLS or PDF programs they would do the same (unless they are good ones that offer to not do that).
Use Windows' built-in Send-To feature to take control of which app opens what files and when: yes, it requires a right-click.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
ssx_Autodesk
Message 3 of 3 (3,926 Views)
10-18-2010 08:24 AM in reply to: pendean
any app i've used that could potentially switch your default app *always* asks.  the autodesk products are the only ones that do not.
we actually have an old custom app that uses an old voloview dll.  imagine the fun that creates! :smileyhappy:
