I'm having the same problems.
I have tried to install Autodesk Design Review 2011 on several computers and all have the same problem.
I get to the "Installation in progress..." screen and it just sits there doing nothing.
I have looked at the logs from our proxy server and that shows me trying to connect to "download.autodesk.com:80" and I'm getting a HTTP status of "Service Unavailable".
Tested the install at home and it worked fine, it must be our corporate firewall / proxy server.
The install must use some odd ball port settings.
Unlike previous version where the install was virtually automatic, I have not been able to get the 2011 version to install. I have tried the suggestions below and removed the various files and registry issues. Although there are no longer any files around, ADR refuses to reinstall or even recreate the folders I removed. The 2011 install disk tells me that the program is installed, the download from the Autodesk site correctly installed Trueview 2011 without and problems and installed a ADR shortcut, which points at "C:\Program Files\Autodesk\Autodesk Design Review Firefox Add-on v1.1\npADRdwf.dll", which is the only file it did install. I have already spend most of the day on this issue and am out of time. I use the program to communicate with other design professionals and have found previous versions to be extremely useful.
Design Review does not and has not previously shown up in the add/remove window and I could not use that feature to uninstall the program before removing the files.
Any help to get this to work would be appreciated.
Could you please go to the Registry Editor to find and remove this key:
[HKEY_CLASSES_ROOT\Installer\Products\7D4B02D8224399043923932FE716A7F6]
Then try to install ADR 2011 again.
Also, you can refer to this link:
