Show only
Search instead for
What is the corresponding syntax in Express to what was tradionally the
following in Whip:
There doesn't seem to be *any* support for setting these properties in this
fashion. Am I missing something? Should I be setting this somehow in
Javascript instead?
Any help would be greatly appreciated on this. TIA,
I believe most of the support is there, but the documentation is rather sketchy. I've yet
to find a list of all params. I have found, for example, that
or
works within the object tag, however the API documentation tells us we should append all
the params to the src url as Thilak has shown. No explanation is given as to why we should
do it that way and IMO it makes the HTML rather difficult to read.
The problem with appending "LayersOn", or perhaps more often "LayersOff" to
the URL string is that long lists of layers get truncated in my experience,
as the URL string can only be so long. I tried that and it was just
hopefully unacceptable.
I ended up wrting a JavaScript function I launched under the OBJECT tag that
calls a function to set my properties for the viewer. Email me if you'd
like the code snippet.
Now, if I could only get the URLs to open in the *same* window as the
drawing ...
Thanks again!
:P
"Joe Blizzard" wrote in message
news:A5FFEF827D7C6A799686413F1D29C182@in.WebX.maYIadrTaRb...
this
sketchy. I've yet
> or
should append all
to why we should
There are two ways in which you can pass the information to EV. One is
through the URL and the other is through the param tags in html. Both of
them should work and have the same behavior.
this
sketchy. I've yet
> or
should append all
to why we should
But, I thought we weren't supposed to used the PARAM tags, as per the AEV
API documentation? When I tried, I didn't have the best of luck as I didn't
know the names of available PARAMs (undocumented). I figured that's why we
were told to use the URL instead in the API documentation.
Then I saw and example that was given for a PARAM that went something like:
All permeatations of this that I tried for more than one PARAM didn't seem
to work. Ie:
"Subu Gupta" wrote in message
news:2673D0D125949BCC50A34B5542A40B76@in.WebX.maYIadrTaRb...
> this
> sketchy. I've yet
> > or
> should append all
as
> to why we should
Use the ViewParams param tag to avoid the parameters from being truncated
off of the URL.
"Peter Lone" wrote in message
news:2BA23A448C31413D1EB8ED591EBE7569@in.WebX.maYIadrTaRb...
> Thanks Subu,
didn't
we
like:
> to work. Ie:
> value="'LayersOn=LAYER1,LAYER2,LAYER3',LayersOff='LAYERA,LAYERB,LAYERC'">
> It was slow going as I was just throwing darts at the board here, so I
> didn't know what to do. Can I do this?
> or perhaps this?
> (BTW, I'm concerned about possible PARAMeter truncation in AEV due to
length
> here) ...
value="LayersOn=LAYER1,LAYER2,LAYER3&LayersOff=LAYERA,LAYERB,LAYERC&NamedVie
> w=TOP">
> or something else? TIA,
in
> > this
rather
> > sketchy. I've yet
> > > or
> > should append all
> as
> > to why we should
Thanks Ben, that's the earlier exampe I saw that I was referring to.
But how to do more than one "ViewerParam"? Is it like:
value="layersoff=BLUELAYER&layerson=REDLAYER&namedview=TOP">
... or perhaps using a collection, ala:
I can't say I've had any luck with either so far. Any suggestions?
Thanks again and in advance,
:P
"Ben Cochran" wrote in message
news:FDD421E76589C98483DB78BCFFAB2A4C@in.WebX.maYIadrTaRb...
> off of the URL.
> > Thanks Subu,
AEV
> didn't
> we
> like:
seem
> > to work. Ie:
> > or perhaps this?
> length
> > here) ...
> > w=TOP">
of
properties
> in
> > > this
> rather
> > > sketchy. I've yet
> > > > or
we
> > > should append all
given
> > as
> > > to why we should
face=Arial>
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">I
just crated three working examples I hope they are
helpful.
size=2>
Using the
param Tags:
size=2><param name="LayersOff" value="BLUE,RED">
size=2>
Using
VBScript:
size=2><script language="vbscript"> function
ShowLayersOneAtATime_VBScript ()
size=2>
size=2> 'Turn all the layers off for
each layer in AdView.Viewer.Layers
layer.Visible = false next
size=2>
size=2> 'Display each layer by itself
for each layer in AdView.Viewer.Layers
layer.Visible = true MsgBox
layer.name layer.Visible =
false next
size=2>
size=2> 'Turn all the layers back on for
layer.Visible = true next
size=2> end function </script >
size=2>
Using
Jave Script:
size=2><script language=="javascript">
size=2> function ShowLayersOneAtATime_JScript ()
{ // Turn all the layers off for (i
= 1; i <= AdView.Viewer.Layers.Count; i++ )
AdView.Viewer.Layers.Item(i).Visible =
false;
size=2>
size=2> // Display each layer by itself
for (i = 1; i <= AdView.Viewer.Layers.Count; i++ )
> Thanks Ben,
that's the earlier exampe I saw that I was referring to. > > But
how to do more than one "ViewerParam"? Is it like: > <param
name="ViewerParams" >
value="layersoff=BLUELAYER&layerson=REDLAYER&namedview=TOP"> >
> ... or perhaps using a collection, ala: > > <param
name="ViewerParams" value="layersoff=BLUELAYER"> > <param
name="ViewerParams" value="layerson=REDLAYER"> > <param
name="ViewerParams" value="namedview=TOP"> > > I can't say I've
had any luck with either so far. Any suggestions? > > Thanks
again and in advance, > > 😛 > > "Ben Cochran"
size=2>ben@nospan.com> wrote in
message >
href="news:FDD421E76589C98483DB78BCFFAB2A4C@in.WebX.maYIadrTaRb">
face=Arial
size=2>news:FDD421E76...
face=Arial size=2>... > > Use the ViewParams param tag to avoid the
parameters from being truncated > > off of the URL. >
> > > > > <param name="ViewerParams"
value="layersoff=BLUELAYER"> > > > > "Peter Lone"
size=2>plone@livingworkplace.com> wrote in
message > >
href="news:2BA23A448C31413D1EB8ED591EBE7569@in.WebX.maYIadrTaRb">
face=Arial
size=2>news:2BA23A448...
face=Arial size=2>... > > > Thanks Subu, > > > >
the > AEV > > > API documentation? When I tried, I
didn't have the best of luck as I > > didn't > > > know the
names of available PARAMs (undocumented). I figured that's why >
> we > > > were told to use the URL instead in the API
documentation. > > > > > > Then I saw and example that
was given for a PARAM that went something > > like: > > >
<PARAM name="ViewerParams" value="LayersOn=LAYER1,LAYER2,LAYER3"> >
one PARAM didn't > seem > > > to work. Ie: > >
> <PARAM name="ViewerParams" > > > >
value="'LayersOn=LAYER1,LAYER2,LAYER3',LayersOff='LAYERA,LAYERB,LAYERC'"> >
the board here, so I > > > didn't know what to do. Can I do
this? > > > <OBJECT ...> > > > <PARAM
name="LayersOn" value="LAYER1,LAYER2,LAYER3"> > > > <PARAM
name="LayersOff" value="LAYERA,LAYERB,LAYERC"> > > > <PARAM
name="NamedView" value="TOP"> > > > </OBJECT> > >
> > > > or perhaps this? > > > (BTW, I'm concerned
about possible PARAMeter truncation in AEV due to > > length >
> > here) ... > > > > > > <OBJECT
...> > > > <PARAM name="ViewerParams" > >
value="LayersOn=LAYER1,LAYER2,LAYER3&LayersOff=LAYERA,LAYERB,LAYERC&NamedVie >
> > w=TOP"> > > > </OBJECT> > > > >
> > or something else? TIA, > > > > > >
:P > > > > > > "Subu Gupta" <
href="mailto:subu.gupta@autodesk.com">
size=2>subu.gupta@autodesk.com> wrote in
message > > >
href="news:2673D0D125949BCC50A34B5542A40B76@in.WebX.maYIadrTaRb">
face=Arial
size=2>news:2673D0D12...
face=Arial size=2>... > > > > There are two ways in which you can
pass the information to EV. One is > > > > through the URL and
the other is through the param tags in html. Both > of > > >
> them should work and have the same behavior. > > > > >
> > > "Joe Blizzard" <
href="mailto:blizzard@zmm.cTHEOBVIOUSom">
size=2>blizzard@zmm.cTHEOBVIOUSom> wrote
in message > > > >
href="news:A5FFEF827D7C6A799686413F1D29C182@in.WebX.maYIadrTaRb">
face=Arial
size=2>news:A5FFEF827...
face=Arial size=2>... > > > > > "Peter Lone" wrote >
these > properties > > in > > > > this >
> > > > > fashion. Am I missing something? > >
there, but the documentation is > > rather > > > >
sketchy. I've yet > > > > > to find a list of all params. I
have found, for example, that > > > > > <param
name="LayersOff" value="(THIS, THAT)"> > > > > > or >
> > > > <param name="PaperVisible" value="0"> > >
us > we > > > > should append all > > > >
> the params to the src url as Thilak has shown. No explanation is >
given > > > as > > > > to why we should > >
read. > > > > > > > > > > > > >
Thanks for the reply, Ben. As for your
examples ...
The first one using the PARAM tags, I understand
that one PARAM will work, as I can do this. I've been having problems
gettings *more* than one to work together, as in this example:
size=2><param name="ToolbarVisible" value="0"> <!--
"false" doesn't work either -->
face="Courier New">
As per examples 2 and 3, I have been able to get
these to work prior, as well. But these examples show how to adjust the
settings via user interaction *after* the page and the DWF is loaded.
I wanted to know about the PARAM tags to set up the DWF display on
initial load. Alas, as I cannot seem to get multiple PARAMs to work
together, I have written a JavaScript function that sets up my
DWF properties. It is called on page load (after the OBJECT
element) in lieu of using PARAMs. This works fine, but I just
feel that this couldn't possibly be the right way to do this. I'm also a
bit concerned about doubling the load time, as I'm setting technically up the
DWF twice, once on initial load, and again to get it the way I want it for
display.
Are you familiar with a multiple PARAM issue?
Can you get the multiple PARAMs to work together as in the example I gave
above?
BTW, is there a limit to the length that a VALUE
for a PARAM can be? If I have a long "LayersOff" list (which I do),
could it be truncating and causing the rest of the PARAMs to be ignored?
Just a thought.
Here's a pseudo
example of my working solution for anyone who is having the same
problem(s):
face=Arial>
helpful.
size=2>
Using
the param Tags:
size=2>
Using
VBScript:
size=2>
size=2>
false next
size=2>
size=2>
Using
Jave Script:
false;
size=2>
itself for (i = 1; i <= AdView.Viewer.Layers.Count;
i++ ) { layer =
AdView.Viewer.Layers.Item(i); layer.Visible
= true; alert(layer.name);
layer.Visible =
false; }
size=2>
size=2> // Turn all the layers back on
> Thanks Ben,
I've had any luck with either so far. Any suggestions? > >
Thanks again and in advance, > > 😛 > > "Ben
Cochran" <
message >
face=Arial
size=2>news:FDD...
in message > >
face=Arial
size=2>news:2BA...
why > > we > > > were told to use the URL instead in the
API documentation. > > > > > > Then I saw and example
that was given for a PARAM that went something > > like: > >
value="LayersOn=LAYER1,LAYER2,LAYER3"> > > > > > >
All permeatations of this that I tried for more than one PARAM didn't >
seem > > > to work. Ie: > > > <PARAM
concerned about possible PARAMeter truncation in AEV due to > >
length > > > here) ... > > > > > >
<OBJECT ...> > > > <PARAM name="ViewerParams" >
> > 😛 > > > > > > "Subu Gupta" <
message > > >
face=Arial
size=2>news:267...
can pass the information to EV. One is > > > > through the URL
and the other is through the param tags in html. Both > of > >
> > > > > "Joe Blizzard" <
in message > > > >
face=Arial
size=2>news:A5F...
or > > > > > <param name="PaperVisible"
value="0"> > > > > > works within the object tag, however
the API documentation tells us > we > > > > should append
all > > > > > the params to the src url as Thilak has shown.
No explanation is > given > > > as > > > > to
why we should > > > > > do it that way and IMO it makes the
HTML rather difficult to read. > > > > > > > >
examples ...
face="Courier New">
loaded. I wanted to know about the PARAM tags to set up the
DWF display on initial load. Alas, as I cannot seem to get
multiple PARAMs to work together, I have written a JavaScript function that
sets up my DWF properties. It is called on page load (after
the OBJECT element) in lieu of using PARAMs. This works fine,
but I just feel that this couldn't possibly be the right way to do this.
I'm also a bit concerned about doubling the load time, as I'm setting
technically up the DWF twice, once on initial load, and again to get it the
way I want it for display.
issue? Can you get the multiple PARAMs to work together as in the
example I gave above?
Just a thought.
Here's a pseudo
problem(s):
face=Arial>
helpful.
size=2>
Using
the param Tags:
size=2>
Using
VBScript:
size=2>
size=2>
itself for each layer in
AdView.Viewer.Layers layer.Visible =
true MsgBox
false next
size=2>
size=2>
Using
Jave Script:
false;
size=2>
i++ ) { layer =
layer.Visible = true;
alert(layer.name);
layer.Visible = false; }
size=2>
on for (i = 1; i <= AdView.Viewer.Layers.Count; i++
) AdView.Viewer.Layers.Item(i).Visible =
true; } </script
> Thanks Ben,
But how to do more than one "ViewerParam"? Is it like: >
<param name="ViewerParams" >
"Ben Cochran" <
message >
face=Arial
size=2>ne...
wrote in message > >
face=Arial
size=2>ne...
tags, as per the > AEV > > > API documentation? When
I tried, I didn't have the best of luck as I > > didn't >
that's why > > we > > > were told to use the URL
instead in the API documentation. > > > > > > Then I
saw and example that was given for a PARAM that went something > >
like: > > > <PARAM name="ViewerParams"
didn't > seem > > > to work. Ie: > > >
at the board here, so I > > > didn't know what to do. Can
I do this? > > > <OBJECT ...> > > > <PARAM
<PARAM name="NamedView" value="TOP"> > > >
</OBJECT> > > > > > > or perhaps this? >
to > > length > > > here) ... > > > >
name="ViewerParams" > > > > > >
in message > > >
face=Arial
size=2>ne...
URL and the other is through the param tags in html. Both > of >
> > > > > > "Joe Blizzard" <
wrote in message > > > >
face=Arial
size=2>ne...
I have found, for example, that > > > > > <param
however the API documentation tells us > we > > > >
should append all > > > > > the params to the src url as
Thilak has shown. No explanation is > given > > >
as > > > > to why we should > > > > > do it
that way and IMO it makes the HTML rather difficult to read. > >
