DWF Viewer (Read Only)
Changing Views via VBA
3 REPLIES 3
308 Views, 3 Replies
I've created a form with the EV control. I'm able to load a drawing, toggle layers on and off, I stumped when it comes to switching views via code. I have named views that were created in AutoCAD r14, they appear when I click the layer button in the control, I just can't do it through VBA code. I've looked through the help files and found an example on how to cycle through each of the view names, but not how to change to a view.
3 REPLIES 3
I found it, its not very obvious (at least not to me) based on the help files.
Dim Viewer As AdPageView.IAdPageViewer
Set Viewer = CAdViewer1.Viewer
Viewer.[_View] = "LAB1"
and of course none of the above post make sense because the HTTP interface. Let me try one more time;
Line1 Dim Viewer As AdPageView.IAdPageViewer
Line2 Set Viewer = CAdViewer1.Viewer
Line3 Viewer.[_View] = "PutNameHere"
Here is a sample code:
Private Sub Command1_Click()
Dim viewer As IAdPageViewer
    Set viewer =
CAdViewer1.viewer
    'Set the view
current.
    viewer.view = viewer.NamedViews("v1")
End
Sub
Private Sub Form_Load()
CAdViewer1.SourcePath = "C:/dwf.dwf"
End Sub
If you are embedding in an html page and wish to
pass it as a parameter then do as follows:
http://tmp.dwf?namedview="v1"
cheers,
thilak
and
try one more time;
Line2 Set Viewer =
CAdViewer1.Viewer
"PutNameHere"
