DWF Viewer (Read Only)
Changing PaperVisible Property via API
2 REPLIES 2
242 Views, 2 Replies
Changing the viewer PaperVisible property from true to false using the API, in an already loaded page, does not hide the paper shadow border. It only hides the paper color.
It works correctly when I perform the same action from the context menu. Is this a bug in the API or am I do something wrong?
Code sample:
// Change the Express Viewer source
oCAdViewer.SourcePath="test.dwf";
// Change the viewer properties
with (oCAdViewer.Viewer)
// Wait until the page finishs loading
WaitForPageLoaded();
// Hide the toolbars
ToolbarVisible=false;
// Hide the paper background
PaperVisible=false;
// Execute this command
ExecuteCommand("FITTOWINDOW");
2 REPLIES 2
Reposting code sample to make it easier to read:
// Change the Express Viewer path
&nsbp;&nsbp;// Wait until the page finishs loading
&nsbp;&nsbp;WaitForPageLoaded();
&nsbp;&nsbp;// Hide the toolbars
&nsbp;&nsbp;ToolbarVisible=false;
&nsbp;&nsbp;// Hide the paper background
&nsbp;&nsbp;PaperVisible=false;
&nsbp;&nsbp;// Execute this command
&nsbp;&nsbp;ExecuteCommand("FITTOWINDOW");
Unfortunately I'm not seeing the same problem as you are. I'm trying to
reproduce this problem using VBScript and events. Here is what I'm working
with, which seems to work properly.
script language="vbscript">
' This demonstrates catching an event '
function AdView_OnEndLoadItem(name, data, result)
if name = "DOCUMENT" then
AdView.Viewer.ToolbarVisible = false
AdView.Viewer.PaperVisible=false
AdView.Viewer.ExecuteCommand("FITTOWINDOW")
end if
end function
/script>
Please try this code and see if you still have a problem.
"felipe2k3" wrote in message
news:f1a01fa.0@WebX.maYIadrTaRb...
