I have tried to upgrade an older version of Volo View Express to the new version vve201. When installing, I'm prompted to uninstall the older version first. Went to Add/Remove programs and uninstalled the old version. Went back to install the new version and get the same message - "uninstall older versions before installing new version". I've done this several times with the same results. How do I uninstall this prgram? After running the Add/Remove function so many times - I think there's a lot of pieces missing and a lot still in the system. Is there an uninstall patch file to sweep everything clean available from AutoDesk?
I'm running this on an HP laptop with WinME
Steve
