DWF Viewer (Read Only)
bug in OnExecuteURL event handling ?
2 REPLIES 2
257 Views, 2 Replies
I use Express Viewer build 3.1.0.78 in a C# application through its COM
interfaces.
All is functioning quit well, except that I can register my own OnExecuteURL
event
handler, that is called fine, when I click on an URL in the Express Viewer,
but I can't stop Express Viewer opening the internet explorer and try to
execute the URL also.
The documentation says:
Setting the eventHandled parameter to a value other than 0 informs the
control that another application wishes to override the default behavior.
I have done this, but the internet explorer is opened always and it can't
interpret my special application specific URL 😉
BUG or fault of me or feature ? Any ideas ?
code sample:
Initialization:
axCAdViewer1.SourcePath ="C:\\Dokumente und Einstellungen\\wagnerma\\Eigene
Dateien\\Projekte\\VABP\\daten\\dwf\\A560-01.dwf";
AdPageView.CAdPageViewer iPageViewer =
(AdPageView.CAdPageViewer)axCAdViewer1.Viewer;
iPageViewer.OnExecuteURL += new
AdPageView._IAdPageViewerEvents_OnExecuteURLEventHandler(OnExecuteURL);
Eventhandler:
private void OnExecuteURL(string url,ref object eventHandled)
System.Console.Out.WriteLine("url:"+url);
eventHandled = 1;
Thanks for your help.
Best regards,
Marcel Wagner
2 REPLIES 2
Looks like a doc error. Down in the internals, our "handled" flags are
looking for VARIANT_TRUE to determined whether or not the event is handled.
I believe VARIANT_TRUE is defined as -1, so if you set your handled flag
to -1, it should work fine.
Hope that helps.
"Marcel Wagner" wrote in message
news:50B4167210E15FBF443C0ECE2B50A506@in.WebX.maYIadrTaRb...
> interfaces.
OnExecuteURL
> event
Viewer,
> code sample:
> Initialization:
> Eventhandler:
> eventHandled = 1;
> Best regards,
> Marcel Wagner
yep, doc error, -1 works like advertised 😉
check also the doc of the other events. they prefer a return value greater
0, but I think
-1 is also the only correct value.
Marcel
"Jeffrey Klug (Autodesk)" schrieb im
Newsbeitrag news:2D6D313FCAE62A499BFDCD48BC3A570C@in.WebX.maYIadrTaRb...
handled.
> Hope that helps.
> > interfaces.
> OnExecuteURL
> > event
> Viewer,
behavior.
can't
> > code sample:
> > Initialization:
> > Eventhandler:
> > eventHandled = 1;
> > Best regards,
> > Marcel Wagner
