DWF Viewer (Read Only)
187 Views, 3 Replies
Autodetect?
Does anyone know of a JavaScript or VBScript that can detect which Autodesk
plugin (Whip!, VV or AEV) a user has installed, if any?
TIA,
:P
Peter B. Lone
Living Workplace Corporation
+1 240-683-6060
FAX +1 240 683 6070
3 REPLIES 3
Search
http://discussion.autodesk.com/
for
detect express viewer
and you will find your answer in a message of april 23
Dijkoraad IT bv
J. Groot Lipman
"Peter Lone" wrote in message
news:45DF04308E1F819719C2EB6966B8BEAA@in.WebX.maYIadrTaRb...
> TIA,
> Peter B. Lone
> +1 240-683-6060
> FAX +1 240 683 6070
Got it. Thanks!
:P
"Jos Groot Lipman" wrote in message
news:308D46CDC7D437169A7625797CA9BF77@in.WebX.maYIadrTaRb...
> Search
> for
> Dijkoraad IT bv
> J. Groot Lipman
> Autodesk
> > TIA,
> > Peter B. Lone
> > +1 240-683-6060
> > FAX +1 240 683 6070
If you used what I posted please double check the Express Viewer check. I
had it fail on one PC recently otherwise it has worked fine on 100's of
others. I posted the code found at
http://discussion.autodesk.com/WebX?displayMessages@181.EYSya3KVoEb.5@.f15bd
9d/0#2 Please let me know if you find a problem with it. I haven't had time
to check it further myself.
ljb
