Show only
Search instead for
I have used the following code, unsuccesfully, embedded in an html page to allow a web site visitor to automatically check for the presence of the AE Viewer then download and install it, if needed. I don't remember where I got it, but the codebase looks incomplete. Can anyone troubleshoot it? Thanks in advance
The best example of how to do this is on the Autodesk Express Viewer
download page.
If you go to http://www.autodesk.com/expressviewer and then register and
then go to the download page, do a "View Source" in your browser to see the
HTML source code of the download page that includes a CODEBASE parameter.
[Note: if you haven't seen the AEV download page in a few weeks look at it
now: it has changed from being Setup.EXE based to be CAB auto-install
based.]
If you look at the source code on that page you'll see the CODEBASE is set
to:
"mll" <> wrote in message news:f15a745.0@WebX.maYIadrTaRb...
Sorry that didn't work, it actually showed the viewer instead of the code I
used?
here is what I tried to use (without the carrots)
object classid="clsid:A662DA7E-CCB7-4743-B71A-D817F6D575DF"
codebase="http://www.autodesk.com/global/expressviewer/installer/ExpressView
" width="900" height="450" id="flowchart"
