Brian,
The Express Viewer looks great!
I would like to move my VB application from Whip! to Express when the API
has been further developed.
Here are a few things I would like to see added to the Express View API.
1. Bypass the Express print dialog box and control the print settings via
the API. This would allow batch printing of dwf files.
2. Add a watermark or text to the print. Currently I use the merge dwf
feature of the Whip! API.
3. Disable the right-click menu.
Bob
"Brian Mathews [Autodesk]" wrote in message
news:1E13327B729142D8B353CB755B29FB43@in.WebX.maYIadrTaRb...
> Yes, you can have both WHIP and Express installed on the same computer.
> Each of these ActiveX controls has its own class ID GUID, so if you author
> HTML pages with embedded DWF files you can specify which of the two
viewers
> you would like instantiated. The same holds for when you are embedding
one
> of these viewers in your own custom application (like VB, etc.).
> However, only one application can be registered to open the DWF file from
> Windows Explorer. When you double-click on a DWF file in Windows
Explorer,
> the last viewer application that you installed is the one that will be
> launched to view the DWF (either WHIP or Express).
> The Express API will be growing in the next release. If you need time to
> transition and need the old WHIP API, theWHIP viewer is still available at
> the ftp://ftp.autodesk.com/pub/whip area as it always has been.
> -Brian
> "Greg Toews" wrote in message
> news:C8275B36F43C0BC83A5F7E31A9260D5D@in.WebX.maYIadrTaRb...
> > The main complaint with Voloview was it did not have the full API that
> Whip
> > did. How does the new Express API compare?
> > Could you have Express and Whip installed on the same computer?
> > Greg
