Ok, a couple of corrections.
Firstly, this fix does not just affect SP2 systems. We don't run SP2 here, we just have the Internet Zone secured to prevent viruses & ad-ware from installing on our company's computers.
Secondly, I can confirm that I am talking about the standard Autodesk release of the DWF viewer, not home grown code. The code you have added to the viewer is a partical fix, and addresses the main issue created with SP2 - that of a more secure Local Computer zone. It does not help when your viewer is running on a computer that also has a secure Internet zone.
The code you added means that your viewer executes the included pages as if they were running from the Internet zone. Since we have secured the Internet Zone to protect our computers from viruses, we still have issues running the software. If you modify your code as I suggested, your code will run as if it were being launched from the autodesk.com website. This is far more specific than just running your code from 'Internet', and allows us to add autodesk.com to the 'Trusted Sites' zone where permissions are already set to allow the program to run.
I have manually made these corrections to your program myself, as have several other people on these boards and I can confirm that it does work as I have explained. The Microsoft articles on the 'Mark of the Web' feature describe this function in more detail.
I really do need Autodesk to fix this so that I can get on with deploying the new version of the viewer across our company.
Ross Smith MCP, MCSA
Network Manager
Robinson Construction
"Jason Bull" wrote in message news:41afb61d_3@newsprd01...
Aceralice and Ross,
First of all, the AEV4.0 ActiveX security warnings on NT.
This is a problem with your IE Security settings; start IE, go Tools->Internet Options and select the Security Tab. Under this tab, you can select Internet, Local intranet, Trusted sites and Restricted sites. I am presuming that you are accessing DWFs from your Local Intranet, so click that icon and then click the Custom Level... button. You will see a dialog allowing you to select various levels of security for ActiveX, Cookies, Scripts and so on. The penultimate ActiveX option is most likely the one that is causing you problems; Run ActiveX Controls and Plugins. To remove the warnings, that needs to be set this to Enable.
The reason that you are seeing this problem is that, as you may have now guessed, the AEV 4.0 is indeed an ActiveX control (which is why it can run embedded in IE in the first place).
Secondly, the comment shown below being added to HTML file headers.
This is only a fix for the security warnings that appear when running the Viewer, or for that matter *any* ActiveX control embedded in an HTML file, on a WindowsXP system with the new XP Service Pack 2 installed; it has no efect on other Windows versions. Ross, if you have downloaded the ADV 5.0 release from the Autodesk website, you will no longer get those SP2 warnings when running the Viewer itself or if you drag and drop a DWF directly into IE, since we have added this comment to our HTML files. Unfortunately, if you have your own, home-cooked HTML hosting the ADV 5.0, you will still get these warnings, and you will need to manually add this comment to your HTML, and unfortunately there is nothing that Autodesk can do about that. This is a Microsoft thing and, as I mentioned, you will see the same warnings with any ActiveX control embedded in an HTML file running on WinXP SP2, not just the Viewer. Believe me, we heartily wish it were otherwise as the release of XP SP2 has caused us some serious headaches and a good deal of unexpected work.
I hope that this helps.
Jason Bull
Senior QA
Autodesk Viewers Group
"Ross Smith" wrote in message news:417fa7a6$1_1@newsprd01...
I'm not sure if this will work with NT, but it's worth a try since I think it's an Internet Explorer issue rather than being specific to NT.
In the DWF viewer folder, edit all the .htm files you can find and replace the top
line with "". Then add
www.autodesk.com to your trusted sites within Internet Explorer.
See my post dated 26/10 for some explanation of this and my rant at Autodesk - I'm not impressed that I've had to fix this myself when so many other people are experiencing the same problem
I'd be very interested to hear whether this fixes your particular problem, can you please reply to this post with your results.
thanks,
Ross Smith
Network Manager
"Aceralice" wrote in message news:230_f197d27.-1@WebX.maYIadrTaRb...
I am using IE 5.5 and have just installed AEV 4.0 on a NT4 PC. I am getting security messages re ActiveX controls and don't know which setting to adjust to get AEV to work.
AEV 3.1 didn't give me these messages, so I am confused.
Any advice for me ? Thanks.
