Using the latest version of the viewer, SimplePrint selects the orientation
based on the orientation of what is being printed. If the DWF page is
landscape, the output is landscape. If you require more control over the
output, PrintEx is an option.
Ben
"Bob H." wrote in message
news:4871627@discussion.autodesk.com...
VB6
I would like the API to...
SimplePrint - Add a parameter for printing landscape. Most users have their
printer set to portrait. It would be nice to be able to use SimplePrint and
have it print landscape.
Control visibility of all toolbar and browser items. E.G.; Browser -
Views/Properties panes
Next / Previous cache should be cleared when a new dwf is opened.
Be able to customize built in toolbar to add a button and fire an event.
A more complete API help file with examples.
"John Schmier (ADSK)" wrote in
message news:4865367@discussion.autodesk.com...
Post them here, the designers pull items from this newsgroup and assess if
they should be in the product.
news:4865206@discussion.autodesk.com...
Is there a way to get some "wish list" items added to the next API release?
"Ben Cochran" wrote in message
news:4865159@discussion.autodesk.com...
Thank you John, I should have pointed this out.
The 3D APIs WILL change in the next release.
Ben
message news:4865121@discussion.autodesk.com...
If you used the unpublished API's they may not be available or may change
between releases. We do not publish these API's because they are not
finalized and may change from one product release to the next. If you use
these API's you may need to update your applications when the next release
of the viewers comes out.
news:4865022@discussion.autodesk.com...
>> Is it possible to change the color of object?
Using an unpublished API you can select an object, other then that you can't
change the color.
>> Is it possible to get some object identifier, which is defined in
>> autocad2006 (parameter, attribute, etc.)?
Using an unpublished API this is possible.
>> Is it possible (i guess no but in future builds... may be...) to crosscut
>> all objects in view like ModelPress does?
This is on the wish list for future releases.
Ben
wrote
in message news:4864680@discussion.autodesk.com...
Good day!
Thanks!
