DWF Viewer (Read Only)
3DDWF Viewer API "Is it possible" questions
11 REPLIES 11
Message 1 of 12
373 Views, 11 Replies
Good day!
Is it possible to change the color of object?
Is it possible to get some object identifier, which is defined in autocad2006 (parameter, attribute, etc.)?
Is it possible (i guess no but in future builds... may be...) to crosscut all objects in view like ModelPress does?
Thanks!
11 REPLIES 11
Message 2 of 12
Using an unpublished API you can select an object, other then that you can't
change the color.
Using an unpublished API this is possible.
This is on the wish list for future releases.
Ben
wrote in message news:4864680@discussion.autodesk.com...
Good day!
Thanks!
Message 3 of 12
If you used the unpublished API's they may not be available or may change
between releases. We do not publish these API's because they are not
finalized and may change from one product release to the next. If you use
these API's you may need to update your applications when the next release
of the viewers comes out.
"Ben Cochran" wrote in message
news:4865022@discussion.autodesk.com...
change the color.
Ben
Good day!
Thanks!
Message 4 of 12
Thank you John, I should have pointed this out.
The 3D APIs WILL change in the next release.
Ben
"John Schmier (ADSK)" wrote in
message news:4865121@discussion.autodesk.com...
change the color.
Ben
Good day!
Thanks!
Message 5 of 12
Is there a way to get some "wish list" items added to the next API release?
news:4865159@discussion.autodesk.com...
Ben
change the color.
Ben
Good day!
Thanks!
Message 6 of 12
Post them here, the designers pull items from this newsgroup and assess if
they should be in the product.
"Bob H." wrote in message
news:4865206@discussion.autodesk.com...
Ben
change the color.
Ben
Good day!
Thanks!
Message 7 of 12
First of all, thanks a lot for the reply!
Pardon. I'm still confused a bit. First of all - where can i grab that unpublished API? What is that - another active-x or just wrapper to existing autodesk controls?
And one more question, the last one (sorry for inconvenience/offtopic): how can i add custom properties for a 3dsolid said so in autocad 2005,2006? Just i'm in need in quick start.
Message 8 of 12
All the viewer APIs published and unpublished are shipped with the viewer.
The difference is that Autodesk will change the unpublished APIs with most
releases. Additionally, Autodesk not does encourage using the unpublished
APIs and will likely not help you use them.
The unpublished 3D API is in the EModelViewer.dll open it up in an OLE
object browser
(http://www.microsoft.com/windows2000/techinfo/reskit/tools/existing/oleview-o.asp)
and you will see the methods on this API. The samples I posted are in C#.
Are you looking for samples in some other language?
I don't know much about publishing objects from AutoCAD, hopefully someone
else can help with that question or you may want to ask in the AutoCAD news
group.
Ben Cochran
wrote in message news:4865584@discussion.autodesk.com...
autodesk controls?
Message 9 of 12
no. i've compiled that sample. Good enough.
Message 10 of 12
VB6
I would like the API to...
SimplePrint - Add a parameter for printing landscape. Most users have their
printer set to portrait. It would be nice to be able to use SimplePrint and
have it print landscape.
Control visibility of all toolbar and browser items. E.G.; Browser -
Views/Properties panes
Next / Previous cache should be cleared when a new dwf is opened.
Be able to customize built in toolbar to add a button and fire an event.
A more complete API help file with examples.
message news:4865367@discussion.autodesk.com...
Ben
change the color.
Ben
Good day!
Thanks!
Message 11 of 12
Using the latest version of the viewer, SimplePrint selects the orientation
based on the orientation of what is being printed. If the DWF page is
landscape, the output is landscape. If you require more control over the
output, PrintEx is an option.
Ben
news:4871627@discussion.autodesk.com...
VB6
Ben
change the color.
Ben
Good day!
Thanks!
Message 12 of 12
Thanks again Ben. I checked it out and v6 does choose the correct print
orientation. Very nice!
news:4871709@discussion.autodesk.com...
Ben
VB6
Ben
change the color.
Ben
Good day!
Thanks!
