Hi
would like to ask you guys, if there's a way to convert the layer and lineweight of xref files to set as background color,
As a mechanical Design Engineer. I constantly strugles with the layer used by architect to use as my background for mech plans.
I currently use a revit project and the layers on archi plans are automatically converted to halftone when linking.
Is there also a command or function that do the same with autocad 2014?
RMV
Solved by jggerth. Go to Solution.
Solved by 3wood. Go to Solution.
Open the source file, change color, linetype, lineweight, etc of everything to ByLayer.
Xref the source file as your background, the in Layer Manager, change the color of xref layers to whatever you like.
If you just want the on-screen display to be faded, use the XFADECTL setvar and set between 0 and 90.
If you are using a ctb to plot, and you want the arch info faded, then as 3wood noted you will need to reset the colors of the entiies/layers in the Xref to be bylayer and control the color of the Xref in the active plottable file using layer colors.
The SETBYLAYER command makes short work oif that task -- just open the Xref file for editing, and run that command.
thanks for the replies.
I'm attaching the sample of what we usually do.
on the sample1sss. drawing "A"- is the acceptable plan set up.
what i did is I usually copy the fp of the acrhi plan sa paste it on my mech cad file. then select all elements and set it to the 1 layer then use it as my backround sometimes i block the entire fp. for easy update..
On drawing "B"- the archi plan is xref to my mech cad file.
this is much quicker than on Drawing A esp. when new set of arch plan arrives, the problem is, notice the linewieght of archi. plan it is much thicker than our standard.
hope you can help me with this one.
thanks
This is a typical use of xref between different disciplines.
My work flow is as below:
1. Open xref file, use CHZ20 (in attachment) to change color & lineweight to BYLAYER.
2. Save the file.
3. Open the master file, in Layer Properties Manager, change all layer color and lineweight as you wish.
4. When new architectual drawings arrive, run CHZ20 on it again, save file and reload xref in the master file.
You may need repeat Step 3 because the new file may contain new layers.
Remember set VISRETAIN to 1 in the master file so it keeps all layer property setting overwrties.
Step 1 - CHZ20 settings:
Step 3 - Change color and lineweight of all xref layers as you like.
Result:
it's worth noting that the SETBYLAYER command in the later versions of AutoCAD will handle the coversion or properties to ByLayer without adding any 3rd party programs, and will also step into block defintions, resetting them to ByLayer properties as well.
Just type SETBYLAYER at a command prompt, and rock on.
