Drafting Techniques
Drafting Techniques
*MMONROY
Post 1 of 12
non coplanar lines
1804 Views, 11 Replies
08-16-2001 03:39 AM
what does it mean when the command line says "lines are non coplanar" when
trying to make a fillet?
*Scott, John
Post 2 of 12
Re: non coplanar lines
08-16-2001 03:39 AM in reply to: *MMONROY
Different Z coordinates.
"MMONROY" wrote in message
news:175A678E88D05600A3FBFB7D0BCCB1D4@in.WebX.maYIadrTaRb...
*Jolley, Alfred C.
Post 3 of 12
08-16-2001 03:53 AM in reply to: *MMONROY
assuming that you are not working in 3-D you probably have an endpoint with
a Z value other than 0 or different than the other endpoints. List you lines
and check out their Z values. When working in 2_D I have found this to
happen when you have some rouge entity/block in you drawing with a Z value
and you osnap to this entity and so inadvertently create a line with
differing Z values.
if you are working in 3-D imagine that you place a sheet of glass on one of
the lines you are trying to fillet. Now rotate the sheet of glass using this
line as its axis. When you hit the second line you will find that you can
not get both endpoints of the second line to be on the sheet of glass at the
same time. The lines are not coplanar.
*Dibbs, Pete
Post 4 of 12
08-16-2001 10:42 PM in reply to: *MMONROY
Type "flatten" at the command line this will send everything to 0.00 on your
Z axis..Pete
*Richardson, Randy
Post 5 of 12
Re:
08-17-2001 01:50 AM in reply to: *MMONROY
Looks like you have a custom application that automatically loads. Flatten
is not a standard AutoCAD command (unless it's been added to 2002).
*Scott, John
Post 6 of 12
Re:
Flatten is a Lisp routine and a very handy one at that. I have it if you
would like me to send it to you. Just let me know.
"Randy Richardson" wrote in message
news:731F0D28A92BDB7EAB055EAA90143BB1@in.WebX.maYIadrTaRb...
Flatten
*Medina, Alfredo
Post 7 of 12
08-18-2001 03:55 AM in reply to: *MMONROY
It means that both lines were not created using UCS (User Coordinate System
that are parallel. Therefore they are not considered as coplanar.
An easy way to correct this problem is this one:
1) Ucs > Entity (or Object) > Select the line that is not parallel to the
current Ucs.
2) Make a block with that line, using one of its endpoints as the insertion
point.
3) Switch to the other line's Ucs by using Ucs > Entity (or Object) on the
other line. (You might need simply to return to the World Ucs, if that is
the common Ucs for your entities.)
4)Insert the block and explode it. Now, both lines must belong to the same
Ucs, and you can use Fillet or Pedit, or any other similar command that
requires both entities to be coplanar.
Alfredo Medina
alfmedina@hotmail.com
Moderator
*Medina, Alfredo
Post 8 of 12
Re:
08-18-2001 04:04 AM in reply to: *MMONROY
Oops. Correction : Two Ucs can be *paralel* and yet not coplanar. Coplanar
means that they their XY grids share the same plane, even though the origin
points are different.
Alfredo Medina
Moderator
Distinguished Contributor
0 Kudos
Post 9 of 12
09-20-2001 07:15 AM in reply to: *MMONROY
when it happens to me i just use a circle ttr
0 Kudos
Post 10 of 12
09-21-2001 04:50 AM in reply to: *MMONROY
If you have a problem with 2D non-coplanar lines and want to move all lines to 0.0 then:-
on the command line type CHANGE - select objects you wish to change by window picking or crossing or even select the whole drawing - PROPERTIES - ELEVATION and enter new elevation of 0.00 and enter. All 2D lines selected will be set to 0.00
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
