Drafting Techniques
Drafting Techniques
econnerly
Message 1 of 8 (811 Views)
Need LISP to draw line / pline to match TEXT rotation!
811 Views, 7 Replies
10-07-2011 12:10 PM
I have searched everywhere but have found nothing. There are a ton of lisp to match text rotation to a selected line, but not vice versa.
Anyone out there have anything?
coopdetat
Message 2 of 8 (793 Views)
Re: Need LISP to draw line / pline to match TEXT rotation!
10-10-2011 08:53 AM in reply to: econnerly
I have a routine I use to rotate viewports which first sets the snapangle to the selected object rotation. If you select text and then escape the routine you can place a line with ortho on to get what you want. I don't think it works with mtext though.
http://www.paracadd.com/lisp/rotx.lsp
HTH
---------------------------------------------Signature--------------------------------------------
Civil Design Professional Since 1983 (Intergraph), AutoCAD since 1989
Windows 7 Professional 64-bit - Service Pack 1
Intel﴾R﴿ Core﴾TM﴿ i7-3820 CPU 3.60GHz; 16 GB DDR3 Dual Channel RAM
nVidia Quadro 4000; AutoCAD Civil 3D 2014, sp1
GrantsPirate
Message 3 of 8 (788 Views)
10-10-2011 01:05 PM in reply to: econnerly
Use UCS, Ojbect option, pick text
I have a simple macro so I type UO, pick the object.  And UW for UCS, World to get back.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Valued Contributor
Rosebm
Message 4 of 8 (682 Views)
08-27-2012 03:16 PM in reply to: econnerly
I have autocad 2011. Use ALIGN command. It rotates an object the way it rotates text like TORIENT command, only vise versa. align can rotate any object.
ROse
smaher12
Message 5 of 8 (548 Views)
03-14-2013 06:20 AM in reply to: econnerly
This will set your snapang to the selected text angle. HTH
(defun C:tmp ()
   (setq esel (entsel "\nSelect text: "))
   (setq edata (entget (car esel)))
   (setvar 'snapang (cdr (assoc '50 edata)))
  (princ)
New Member
sraja10005069
Message 6 of 8 (336 Views)
02-12-2014 07:39 AM in reply to: econnerly
DEAR SIR / MADAM
SUBJECT :- ISA ANGLE LISP
Spoiler
IAM WORK IN PRIVATED COMPANY  I USED AUTOCAD 2012 VERSION  IAM ATTACHED THE AUTOCAD DRAWING FULL DETAILS  YOU SEE  SIR AFTER YOU SEND THE ANSWER SIR PLEASE HELP HELP HELP.............
smaher12
Message 7 of 8 (326 Views)
02-12-2014 06:48 PM in reply to: econnerly
This is one I use.
;;; Tip1556:  TXTROT.LSP    Text Rotate    (C)1999, William E. Barlow
;;; Rotates text to align with selected line
(defun C:txtrot ()
  (setvar "CMDECHO" 0)
  (Princ "\nSelect line...")
  (setq LINE (ssget))
  (setq INDEX 0)
  (setq ENAME (ssname LINE INDEX))
  (setq ELIST (entget ENAME))
  (setq PT1 (cdr (assoc 10 ELIST)))
  (setq VALUE11 (car PT1))
  (setq VALUE12 (cadr PT1))
  (setq VALUE13 (caddr PT1))
  (setq PT2 (cdr (assoc 11 ELIST)))
  (setq VALUE21 (car PT2))
  (setq VALUE22 (cadr PT2))
  (setq VALUE23 (caddr PT2))
  (setq LANGLE (angle PT1 PT2))
  (setq P12 (/ pi 2.0))
  (setq P32 (* pi 1.5))
  (setq P2 (* pi 2.))
  (if (and (>= LANGLE 0.0) (<= LANGLE P12))
    (setq NARCTAN LANGLE))
  (if (and (>= LANGLE P32) (<= LANGLE P2))
  (if (and (>= LANGLE P12) (<= LANGLE pi))
    (setq NARCTAN (+ LANGLE pi)))
  (if (and (>= LANGLE pi) (<= LANGLE P32))
    (setq NARCTAN (- LANGLE pi)))
  (Princ "\nSelect text...")
  (setq TEXTL (entget (car (entsel))))
  (setq OTEXT (assoc 50 TEXTL))
  (setq NTEXT (cons 50 NARCTAN))
  (setq TEXTL (subst NTEXT OTEXT TEXTL))
  (entmod TEXTL)
(princ)
Kent1Cooper
Message 8 of 8 (317 Views)
02-14-2014 05:48 AM in reply to: sraja10005069
sraja10005069 wrote:
DEAR SIR / MADAM
This seems un-related to the Subject of this thread.  If someone offers a good solution, it will be much more difficult for anyone else to find and use than if you start a new thread about this specific Subject.  I would suggest you post your question on the Customization Forum.
Kent Cooper
