Hi all,
I need the following picture as to be a drawn entity in my drawing i.e. a block. I already know that there is no way rather than using attach clip and try to draw over it. Can anyone help me with this particular case?
Regards
IIRC WinTopo was a freebie that could do simple things like that fairly well.
If you've got access to Corel or Illustrator, that should give you easy path tracing tools and export to dxf at least.
Ouit of curiosity - what's the original source for that sign?
Contact Seton in Australia. They may have an Autocad drawing they can send you for a drawing.
If it's a vector PDF you can usually get the linework back out using Inkscape (free software). I just downloaded a PDF from seton.net that had a variety of signs on it, opened the PDF in Inkscape, and then saved the results as an AutoCAD R13 DXF. It works though it's not always the prettiest thing (text is exploded, lots of splines).
Hope that helps!
