Drafting Techniques
Drafting Techniques
New Member
jineeshkumarmp
Message 1 of 9 (6,828 Views)
How to change the base point of a block?
6828 Views, 8 Replies
07-31-2011 05:35 AM
I wish someone will help me. I have around 10 blocks in a file in different places. How to change the base of that block with out moving the blocks? Is there any solution?
Charles_Shade
Message 2 of 9 (6,824 Views)
Re: How to change the base point of a block?
07-31-2011 09:12 AM in reply to: jineeshkumarmp
Are these ten different block or the same block ten times?
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
*Pro
nestly
Message 3 of 9 (6,816 Views)
08-01-2011 01:37 AM in reply to: jineeshkumarmp
Valued Contributor
wendyloui
Message 4 of 9 (6,771 Views)
08-02-2011 09:31 PM in reply to: jineeshkumarmp
I "bedit" the block.  When I'm in the block editor I pick up all of the objects selecting the desired base point and move that to 0,0.  There are other ways too but this is the most simple way to do it for relatively simple blocks.  Wendy
Distinguished Contributor
ssx_Autodesk
Message 5 of 9 (6,739 Views)
08-05-2011 03:03 PM in reply to: jineeshkumarmp
BASE command?
(all your BASE are belong to us)
______________________________
~ "if this were /. this would be funny"
Valued Contributor
Rosebm
Message 6 of 9 (6,269 Views)
02-21-2012 01:34 PM in reply to: jineeshkumarmp
Doubleclick on your block (BEDIT) to edit block. move linework to adjust base point. Then BCLOSE. Done.
rOSE
Charles_Shade
Message 7 of 9 (6,266 Views)
02-21-2012 01:39 PM in reply to: Rosebm
And bring all the Parameters with this as well?
And does the OP want the position of all the Blocks to change?
Or just one or several?
Bob_Zurunkle
Message 8 of 9 (6,247 Views)
02-24-2012 09:33 AM in reply to: Charles_Shade
Could OP leave base of block as is and add a grip by adding a point-move?
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted :smileyhappy:
Charles_Shade
Message 9 of 9 (6,245 Views)
02-24-2012 09:50 AM in reply to: Bob_Zurunkle
Not sure, OP has not responded to any suggestion nor offered more detailed info.
