I'm very new to AutoCAD and I was hoping for a little advice. I was wondering if there is a way to automatically set the spacing between your dimensions. For instance I'd like my first dimension to be Xin from the object and the next dimension to be Yin from the last dimension. I use DIMSPACE for this now, but I was wondering if there was a way for the dimensions to automatically go to these X and Y locations when I create them as opposed to adjusting them after I've created all of them.
Any other dimensioning tips would be greatly appreciated.
Thanks! 😄
Solved by troma. Go to Solution.
Mark Green
Working on Civil 3D in Canada
I use tracking to help with my spacing and it is foolproof once you get the hang of it.
Step by step:
1. Start with OTRACK and OSNAP enabled.
2. Select first Extension line origin.
3. Select second Extension line origin.
4. "Roll" over edge of object until you get Tracking started.
5. Type in command line the distance you want away from object - "X" inches.
6. For subsequent dimensions repeat steps 1 thru 5 and substitute the first dimension's terminator for the edge of the object.
All dimensions should be the same distance from your object no matter where they are located and all dimensions will be spaced the same from successive dimension lines.
Set your grid spacing to 3/8 inch. The first dimension standard distance from object is 3/8" and 1/4" there after. It doesn't need to be exact but with repetition and using the grid as a guide you can can dimension real fast! And it looks awesome too! 🙂
