AutoCAD Forum
Custom Linetype display
6 REPLIES 6
808 Views, 6 Replies
I created a some linetypes in Acad 2013 and they don't display at all. I have the ltscale, msltcscale, psltscale all set you 1. Here are the linetypes i created. let me know what i need to change. The existing linetype shows up correctly. any Suggestions?
*COLDWTR,_____ _ _____
A,3,-.125,.125,-.125
*HOTWTR,_____ _ _ _____
A,3,-.125,.125,-.125,.125,-.125
*RECIRC,_____ . . . _____
A,4,-0.2,0,-0.2,0,-0.2,0,-0.2
*EXISTING,_ _ _ _ _ _ _
A,.02,-.02
Tags (1)
6 REPLIES 6
Charles_Shade
Welcome to the Autodesk Forums!
Where did you place these in the *.LIN File?
And which LIN file did you use? acad or acadiso?
Is there a return at the end of the last definition leaving a blank space in the LIN file?
By display do you mean they are Loaded but not visible in Modelspace?
Or are you unable to Load these with the Linetype Command?
in reply to: Charles_Shade
I didn't add the linetypes to the existing .LIN files. I created a new one and added the linetyes from the new file. I don't have a return at the end.
I'm able to load the linetypes but they display as a continuous line except the existing linetype.
I'm unable to get them to show up unless I change the ltscale. If leave the ltscale at 1 the existing linetype shows up fine, just not the other two. Why is that?
rkmcswain
The first segment of your first 3 linetypes is greater than 1 unit, while the first segment of the "existing" linetype is 0.02 units, so it's natural that "existing" would display Ok while the other 3 won't.
Scale down the segments and spaces in the first 3 linetypes, use real world units. If you want a dash to be 0.25" long, use 0.25, etc.
Sorry for the huge image, but it shows you the scale relationship between the 4 linetypes as they are now.
R.K. McSwain     | CADpanacea | on twitter
rkmcswain
in reply to: rkmcswain
Actually, it just took a min to fix.
A,.125,-.125,.125,-.125
A,.125,-.125,.125,-.125,.125,-.125
A,0.2,-0.2,0,-0.2,0,-0.2,0,-0.2
A,.02,-.02
 Results in this.
Charles_Shade
Just what I was showing here.
The RECIRC needed to be near 5 units before the defintion looked like what the OP wanted.
I got it fixed. Thanks for the help. After making the first number smaller it worked fine.
”Boost
