I use CAD 2013, in some drawings I can't copy/paste a particular block (or particular layout). I used Ctrl C & Ctrl V:
After doing Ctrl C & Ctrl V, all it pasred is what had been copy into clipboard previously. That indicate command Ctrl C not working & nothing beeing put into clipboard.
- for Block: In as same layout, I still can do copy/ paste most of things but for some blocks I can't. It happened for paricular blocks in a whole drawing.
- for a drawing layout in paper space, I can't do it for any viewport open in the same layout. But if I open new layout, I still can copy/ paste any viewport.
Is there any setting in layout to stop copy/paste viewports.
any help is appreciate
Regards
Solved by pendean. Go to Solution.
My question is on conmmand Ctrl c/Ctrl v in copy into window clipboard.
I have attached the cad file for you to try.
Thank you for Prompt reply
It works fine here (opened your file in C3D 2013 SP2)
But I have seen cases like you describe where CopyClip seemingly does not work.
Have you tried all the 'normal' steps like audit the drawing, restart the machine, insert the 'bad' drawing into a new empty one, etc.?
Of course I can wblock and re-insert back to the drawing, the funtion Copy/Paste to/from clipboard will work as normal.
I can even re-define the block to make it work. But my question remain on the command Copy/Paste to/from clipboard.The drawing has been audit without any error.
I wonder if there are some settings (or a system variable setting) to stop that command working.
Thank you for your help
