Hi all,
i googled a post about this topic, but sld2dxf from czech site is not working on 64bit system. Is there any other way to make a drawing from slide? I made some slides, but didnt know i was going to use dwg file... so i didnt save 😃
Now im looking a way except drawing it all over again
cheers
It's been a long long long time, but I don't think you want to trust the sld2dxf for accuracy. I think it is a kind of a raster vector/vector raster thing that is only so good. You are probably stuck redrawing. Otherwise you need to find an old computer with AutoCAD. If you are desperate, you might just pop into the 2007/2008/2009 group and see if someone will do it for you.
