Hope this is the correct forum.
Please help?
I have a very curved 3d model that kind of resembles the bell of a trumpet that is slightly flattened on one side. Sorry... I cant post an image as an NDA is in effect. I need to take this concept model and flatten / unfold it for manufacture. The Design carries a very intricate graphic pattern that the client has requested "looks exactly like the rendering". (client supplied a rectangular pattern that I then used UVWunrap to map to te compound curved surface.) Now I have to build it. Yay!
Can anyone reccomend a software that will do just that.... Unwrap / unfold the 3d model into flat panels that can then be converted to a vinyl print layout?
Suggestions / recommendations would be most welcom!
Thanks in advance....
AndyM
Solved by andymiddleton. Go to Solution.
Solved by jonathan.matthews. Go to Solution.
3ds Max should be able to do what you are describing. Start by watching the video at this link http://designreform.net/2007/05/unwraping-geometry
Also, Autodesk Inventor with 'Exact Flat' plug in could also acomplish this.
Jonathan.
Many Many Thanks for that!!!!
Was exactly what I nedded! Awesome.
Andy
