Update Error
Update Error
HughesTooling
Consultant Consultant
Message 1 of 12
Update Error
HughesTooling
I got the update yesterday 28/07/16 and all seemed fine. I did crash Fusion trying to modify an op in the CAM workspace, but it restarted OK. Today when I run Fusion I get an error telling me there's an update error, has there been another update today 29/07/16?
streamer log attached.
Mark
Mark Hughes
Owner, Hughes Tooling
Replies (11)
Message 2 of 12
PhilProcarioJr
@HughesTooling
I fired up Fusion about 30 min ago and I didn't see an update. Fusion is working here.
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 3 of 12
PhilProcarioJr
@HughesTooling
Seems a bunch of people are having this error.
http://forums.autodesk.com/t5/design-validate-document/error-installing-fusion-360-ssl-certificate-v...
Phil Procario Jr.
Message 4 of 12
HughesTooling
Thanks phil
Spotted the other threads just after posting, one has a workaround but I think that's only for a new install not an update.
Mark
Mark Hughes
Message 5 of 12
PhilProcarioJr
@HughesTooling
Sure thing Mark, I hope they get this fixed for the rest of you soon.
Phil Procario Jr.
Message 6 of 12
chrisparris01
I have the same error coming up, hopefully there is a solution.
Message 7 of 12
TheCADWhisperer
Message 8 of 12
HughesTooling
On my other PC I use hibernate and I'd left Fusion running from yesterday, it had yesterday's update. Just noticed this error on that PC so I don't know if another update has been quietly pushed out overnight.
Mark
Mark Hughes
Message 9 of 12
James.Youmatz
Autodesk Support
Autodesk Support
Hi all,
I just got word from the team that this issue should be resolved now! A relaunch of Fusion should trigger the update to go through again and work correctly!
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Message 10 of 12
HughesTooling
Thanks James looks like it's fixed.
Mark
Mark Hughes
Message 11 of 12
chrisparris01
Thank you Fusion - all good now
Message 12 of 12
@James.Youmatz
I just restarted and the issue was gone for me as well.
Chris
